Displays the PIM configuration on a tunnel.
| tunnel | Specifies PIM tunnel. |
N/A.
The following command displays the global PIM configuration and statistics with tunnel configured:
# show pim tunnel mytunnel
PIM SPARSE Interface[2] on VLAN mytunnel is enabled and up
IP adr: 10.0.0.4 mask: 255.255.255.0 DR of the net: 10.0.0.4
DR Priority : 5
Passive : No
Hello Interval : 30 sec
Neighbor Time out : 105 sec
Join/Prune Interval : 60 sec
Join/Prune holdtime : 210 sec
Trusted Gateway : none
CRP group List : none with priority 192
Shutdown priority : 1024
Source Specific Multicast : Disabled
State Refresh : Off
State Refresh Capable : No
Border : No
Generation State DR
Neighbor IP address Id Expires Refresh Priority
10.0.0.3 0x62b56975 104 No 1
Packet Statistics (In/Out)
Hellos 122 123 Bootstraps 62 60
Join/Prunes 0 60 Asserts 0 0
Grafts 0 0 GraftAcks 0 0
State Refresh 0 0
The following command displays the IPv4 multicast forwarding status on a tunnel (line 8):
# show tunnel mytunnel detail
Tunnel Name : mytunnel
Tunnel Type : GRE
Flags : Up
Source Address : 50.1.1.4
Destination Address : 50.1.1.3
IPv4 Forwarding : Enabled
IPv4 MC Forwarding : Enabled
IPv6 Forwarding : Disabled
Virtual Router (VR) : VR-Default
Payload VR : VR-Default
Interface Address : 10.0.0.4/24
IP MTU : 9170
TCP Adjust MSS : IPv4: Off IPv6: Off
TCP MSS Value : IPv4: 0 IPv6: 0
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
